amcananey
Forever a 500+ Head-Fier
- Nov 1, 2010
My experiences trying 12AU7s (and ECC82s), 12BH7s, E80CCs and 6SN7s -- and taking Bottlehead guidance into account -- has firmly convinced me that the best thing to do is to stick with 12AU7s and their ECC82 equivalents. There are plenty of these out there, so you are hardly limiting your ability to roll tubes forever. And you will be using the tubes that the Crack circuit is optimized for.
If your goal is the best possible sound quality, and you don't want to use 12AU7s / ECC82s, then I think you should modify your Crack for the tube type you want to use. For 12BH7s, this means replacing some of the LEDs on the 9-pin socket with resistors. For the 6SN7s, it means replacing the nine-pine socket with an octal socket so you don't need to use an adapter.
This isn't just a matter of convenience, but rather one of performance. I have FOUR 6SN7 --> 12AU7 adapters at home with three different designs from three different manufacturers. They ALL result in unacceptable noise, even when used with 6SN7s that are dead quiet in other amps. And my Crack is dead quiet when used with my various 12AU7s.
Regards,
Adam
Regards,
Adam
