cheznous
- Oct 22, 2010
Works just great. This card is so fast to load direct from my MAC.
Excellent work!! I plan on doing the same with my P1. Can you send me the link to the exact micro sd to sd flex ribbon cable that you are using? Are you using the supplied leather case with the cable and card?
https://linitx.com
SD-Micro to SD Card Adapter @ £14.85 ex VAT = £14.85 ex VAT
Great service. Is tight fit to get case fully on.
What filesystem did you format the 512GB card - fat32, exfat?
No issue on my side with 1.98b
