Jan 15, 2019 at 12:23 AM Post #4,681 of 4,971
@BruceBanner Dude... I have used your EQ formulas for 3 years! That's awesome you chimed in here. I'm on your basshead settings with my PortaPros right now. Sincere thank you for sharing this way back when and then again now for newer folks. :punch: :anger_right: :punch:
I'm on your EQ, or a slight variation, most of the time but I do use "BBE Headphone" every now and again and almost always do when comparing two 'phones.
Haha, well... I can't take all the credit, I didn't at all come up with that combo of settings, some guy on ABI called 'MDWright2035' or some sh!t posted it first, all I did was try it, tweak it, then shout from the roof top about it, hehe. Glad its still working for you :)
Jan 20, 2019 at 7:11 PM Post #4,684 of 4,971
EQ Settings
7 80 wide
-1 220 normal
5 1.4 narrow
5 3.0 normal
6 11.7 wide
bbe 10
mach3 off
3d surround 3
mp enhance on
stereo enhance 3
reverb off
____________________
EQ Settings
7 80 wide
-1 220 normal
5 1.4 narrow
6 3.0 normal
7 11.7 wide
bbe 10
mach3 8
3d 2
mp enhance on
steroe enhance 3
reverb off
Those are the two settings everyone recommends. I don't understand the "Stereo enhance 3" and "reverb off" parts though. When you go to the "stereo enhance" tab you can set the reverb from "off" to "10" but then that means the reverb is "on." So I don't see how you can set it to "3" and set the reverb to "off" at the same time. There is no "off" option in the "reverb mode" section. Did the new firmware change something? Here's a screenshot of what I'm looking at.
Jan 20, 2019 at 7:49 PM Post #4,685 of 4,971
Everyone recommends? Hehe I'm glad my settings are gaining popularity then :D
These settings were first given by someone else that was on the Anythingbutipod forums years ago, iirc I think he went by the handle mdwrite2032 or something. So old are these settings they were used on the really early iterations of Jet Effect/BBE, think back to the original D2/D2+, S9, J3 etc. I used those settings on a i9+, so perhaps at one time these combos worked whereas now not so much? My advice is use your ears, if the settings seem to contradict and/or do nothing then leave that setting off. All I recall doing was getting the settings then doing slight tweaking to suit my IEMs and genres, and because the i9+ had 4 custom user modes would have 4 slight variations of those settings.
Jan 28, 2019 at 2:27 PM Post #4,686 of 4,971
I can't see the available memeory of the micro sd card under "Settings" -> "Information". Am I missing something, or is the Plenue D not capable of doing this?
Can anyone give a clue?
By the way: Does the Plenue D2 also have the horrible boot time due to database update as the Plenue D has? Sleep mode drains the battery, so this is no option.
Jan 28, 2019 at 2:51 PM Post #4,687 of 4,971
I can't see data on my uSD card either within the menu, must not be an option.
Have you updated to the latest v1.20 f/w? The boot time seems faster than previous versions and I agree concerning the Sleep Mode battery drain...can't stand it so I just turn it off. Hopefully D2 may fix those things but I still like the PD non-the-less.
Jan 28, 2019 at 3:23 PM Post #4,688 of 4,971
What a pity not having the option. I have roughly 15.000 files on the card and the boot time is almost the same (like far too long) with v1.17 and v1.20. I reverted to v1.17 though, because I like the look better.
Feb 7, 2019 at 12:54 PM Post #4,689 of 4,971
OMG. I just now discovered the PD has an option to play only tracks added the last day, week and month. My one major complaint about the PD was how creating playlists is difficult. I always want to listen to just the new albums I’ve recently loaded on the player. Don't know if this was in previous firmware but it's new to me and I'm thrilled!
Feb 7, 2019 at 2:17 PM Post #4,690 of 4,971
How do I get that?
Feb 7, 2019 at 2:18 PM Post #4,691 of 4,971
How do we get that?
Feb 7, 2019 at 9:04 PM Post #4,694 of 4,971
Hi everyone,
This is not a nitpick but it helps to look through the options to see what any DAP can do.
That playlist function has been there since the very beginning. :-p
@mdtolic, @Rekkxar, hope the recent playlist options work for what you both need & enhance your listening experience.
Hope you both have a great day !
