mueslitoeter
If you read the related posts before those quotes, you'll see I went through the same thoughts as you - I think many of us Plenue D fans would love to be able to chuck a terrabyte card in them, but we all eventually find out it isn't going to work. Welcome to the club!
Yeah, but then there is still the damn file/folder limit.
Yes, as long as you go slowly gently and carefully, there is no damage caused to the case. It's not one of those products (like some of the old Nokias) that the clips easily break when you pry them open, but I must stress that with the Plenue D, if you want to do it without damage, then it depends on how much care you take. I had no problems at all.
Thanks for the heads up, but I saved myself the hassle opening it, thanks to the tool mentioned by vas-tomsk.
Yes. I found a way to determine whether there is a microSD card inside the COWON PLENUE (D, J, V, D2, D3) players without opening them.
Thank you, the tool worked perfectly. Unfortunately I don't have a microSD card inside.
