jma790
- Jan 31, 2008
Maybe you will be lucky enough to review it Skylab!
Originally Posted by calaf /img/forum/go_quote.gif never heard of this approach to a discrete volume control. Is it something which has been used for other amps? |
Originally Posted by Drosera /img/forum/go_quote.gif Is anyone else wondering what Jan will call his next amp which will probably appear in about 2 years and be even bigger (and better)? I was wondering about this already before the symphony appeared. You can't really go beyond Opera, as far as large musical works are concerned. Well, maybe the Corda Gesamtkunstwerk. |
Originally Posted by Drosera /img/forum/go_quote.gif Is anyone else wondering what Jan will call his next amp which will probably appear in about 2 years and be even bigger (and better)? I was wondering about this already before the symphony appeared. You can't really go beyond Opera, as far as large musical works are concerned. |
Originally Posted by Turgidson /img/forum/go_quote.gif Depends on the work. Some symphonies (like Mahler's 8th) feature much larger musical forces than many operas. Baroque operas use rather small orchestras, as do baroque symphonies. So it's no easy comparison. |
Originally Posted by Turgidson /img/forum/go_quote.gif By the way, it'd be fun if someone would name an amp the 4'33". |
Originally Posted by Drosera /img/forum/go_quote.gif My bet is actually on a numbering scheme, perhaps starting with the Symphony. I'm already curious what Meier's 9th will sound like. (Although he might want to avoid that rather cursed number.) |
Yes, but only if it's broken. |
Originally Posted by Turgidson /img/forum/go_quote.gif That could still be marketed as the first ever 0-gain amp, with unmatched transparency. It's like no amp was even there. |
