yayomizzan
- Mar 20, 2009
looks nice. anyone know how much?
Originally Posted by yayomizzan /img/forum/go_quote.gif looks nice. anyone know how much? |
Originally Posted by koto-in /img/forum/go_quote.gif Arietta is sold out. Swing specs are up - switch to AD8610 opamps as Jan did with the Porta Corda to the Move evolution. |
Originally Posted by Beefy /img/forum/go_quote.gif ...... for how long has Jan been telling us that the LM6171 are the be all and end all of OPAMPs? AD8610 is three times the price at Digikey, so we know it isn't a cost differentiator...... |
Originally Posted by Beefy /img/forum/go_quote.gif Without having a schematic of the Arietta in front of me, I can't say for sure...... but I very much doubt it would be a good idea. LM6171 and AD8610 are pretty different beasts. See here: Working with Cranky Op-Amps |
The LM6171 has bipolar inputs and thereby rather high input biasing currents. To prevent excessive offset-voltage at the output the DC-impedances of the inverting and the non-inverting inputs of each opamp are carefully matched. Also the non-inverting inputs are connected to the negative voltage rail by a 15 MOhm resistor to reduce any biasing current flow through the input potentiometer (which strongly reduces crackling noises) and through the crossfeed filter. The remaining offset voltage is normally smaller than 20 mV. It is recommended not to change any resistor values as this might lead to offset-voltages that could well destruct your precious headphones!!! Warning: FET-opamps have much lower input biasing currents and if you plan to use these instead of the LM6171 the 15 MOhm resistors should be removed! Otherwise offset voltages will be pretty high. |
Originally Posted by koto-in /img/forum/go_quote.gif And from Jan: |
