That and while chips can perform that high, in real practice, most never perform over 115 at absolute best (miraculous even). Running load, I would doubt that even the best headphone amp could sustain 95db.
A few weeks ago i asked Jan Meier about Swing signal to noise ratio, he wrote that for Swing S/N is "Larger then 140 dB More important, due to the concept of the amp noise reduces at lower volume settings. Thus SNR is still very high at low volume settings also".
Hmmmmm...that doesn't sound right. I am going to ask Jan about this.
So Jan sent me some information about this - and the Swing is indeed capable of 140 db S/N ratio - with NO INPUT. There are some smart things Meier has done to keep the S/N ratio low.
Originally Posted by Skylab /img/forum/go_quote.gif So Jan sent me some information about this - and the Swing is indeed capable of 140 db S/N ratio - with NO INPUT.
And that helps in the real world........?
[EDIT] In retrospect, how do you even measure SNR if you aren't measuring the output of the amp with it actually amplifying a signal? It makes no sense.
Originally Posted by Beefy /img/forum/go_quote.gif And that helps in the real world........?
Yeah, I sort of wondered that myself...I'm not sure I quite understand how the measurement was taken, exactly. But that is what the measurements said.
Perhaps if Jan sees this he can explain it better than I can. He's a much more technically astute person than I am. The scale I got was also "dBr", which is "dB relative", so the whole thing wasn't crystal clear to me.
That said, there are some things Jan does in his designs, which I am not sure it makes sense for me to try to explain, that maximize SNR.
Originally Posted by dugforeva /img/forum/go_quote.gif Would this be a good amp to drive the denon D5000's?
I have the Corda Swing driving my Denon D2000's and it works great! I'm sure it will work well with the D5000 also since both have almost the same specs.
