husthn
- Aug 28, 2013
MacedonianHero,I've found you just change the comfort of P7 from 5 to 3.5, is that mean it is not so comfortable? Any details?
Why arent there more full sized portables? It doesn't seem the extra half inch in diameter over some of these small around ear sets that bother some listeners would really make headphones that much less portable.
I myself have been looking for something with the comfort of a full sized but with more portability but options seems few and far between.
This thread (I think I mentioned it in my first post) was for closed/portable headphones for on-the-go only. So for now I suppose, I'd like to keep it on that topic.
Full sized and portables don't really mix IMO. Do you have any in mind?
I see no reason they can't mix. A lot of portables have just slightly smaller than full sized cups. Why not just bumptious that up a half inch or so for more comfort.
The Koss dj100 fit comfortably around my ear and fold flat for bag storage. I see no reason other manufactures don't follow that model instead of having a half assed compromise between comfort and portability.
can someone compare me the 1r with the momentum .
Comfort wise, 1R wins. Sound wise, Momentum wins. It's a "higher end" headphone.
how good is momentum , is it worth $40 more ? they are on-ear to me , i have big ears , i have tried 1r they are nice , but they are a bit over priced here , like $280 , does the 1r has better imaging ? and how bad is aviator , its for $95 here . and whats this s6avfm and s6avdm , two batches of aviator ? or they sound different too ?
You're going to be happier with the 1R. The sonics aren't that far apart from the Momentum, but it's miles ahead in the comfort department, especially if you're someone with bigger ears. As far as imaging goes, I think that's something the 1R does better than the Momentum.
Subjective much.
Sonically I found them to be different enough, especially the Momentum's superior sub bass extension. Also if you're lucky enough to have ears like mine (around 65mm tall), you'll find them to be no less comfortable than the Sonys.
Is it worth $40 more? Personally speaking "yes." Others with big ears will say "no."
