well I would love to hear from people who had 2 daps of the same model and could try 2 different firmwares
because after almost any firmware update of any dap you find someone talking about changes in sound.
every time I owned a dap and did an update I heard no significant change. and every time something major seemed to happen with the firmware, I had already sold that dap. so I'm kind of curious about how much is placebo and how much is real?(or if I just don't have any luck with firmware updates ^_^)
else I think I already mentioned it, but I have a few daps and the clip+/zip and my samsung YP-P3 are sounding kind of flat and really similar. the sonys and cowon, my poor tablet, and even my computer all have noticeable changes and not just in signature or hissing levels. usually I really notice a difference in the imaging, probably just a mix of signature and some high crosstalk levels are enough for those differences. I really can't tell.
but I turned my mother into an experimented switch pusher once, and even with no DSP activated, it was easy to tell what was what(except for clip+ and p3, but the clip+ doing its buffering noise it was still easy to tell ^_^).
anyway with the amps, I have 4sources that sound very much identical on easy to drive IEMs, so that does happen more than we know.
and again I can't tell if it's luck or not, but they are the 4 with the lowest impedance outputs. the sonys and cowon have 3ohm or more. if I had to guess I would say from the signature change with my IEMs that it's above 30ohm(I only have 30 and 100ohm resistors so that all the precision I can give ^_^). the tablet I didn't even try to know, when you press play you commit a crime against music.
