dvw
- Mar 29, 2002
What equipment are you using to do the measurement and what are the result? surely, you must have some note. how does it compare to the chip manufacturer datasheet?
- you don't have access to your own measurements - why on earth would you do that ?
Just went back to my measurements folders and did not find my Ipod one so I did a remeasure, also apologies, I was wrong about the high jitter part, the DX90 has the most jitter between the DX50 and Ipod4g. Reference is off by a little 2.7dBV=3dBFS. Measured with my SB1240 which has pretty good jitter specs.
