thewatcher101
- May 25, 2016
I do use it to drive a pair of LCD x
How long is the battery life on this thing? I only get about maybe 4 hours on it, instead of the promise 8, and my unit is new.
Thanks - bought online via Amazon so will try contacting Chord direct. I don't think it is the other issue (as have suffered this problem in the past with the CCK connector & this seems completely different related to the USB).Apple products have been causing problems with external DACs for several months, ever since an iOS update.
However if yours is rattling as well, it could be that the USB socket has come loose from the circuit board.
You will have a years warranty, so you need to return your mojo to your dealer, so that they can return it to chord.
If this is problematic, because you don't have a traditional dealer (eg ordered online from Amazon), then there is the fallback option of contact Chord via their website, and explain your difficulty, and they usually try and arrange something.
If all else fails, the very last resort is to return your mojo by post, as described here https://www.head-fi.org/f/threads/c...n-3rd-post-◄★☆.784602/page-2118#post-13424397Thanks - bought online via Amazon so will try contacting Chord direct. I don't think it is the other issue (as have suffered this problem in the past with the CCK connector & this seems completely different related to the USB).
Anyone have slight noise/hissing in the background with their mojo? I notice it with my Campfire Audio Andromedas, although with cheaper IEMs I don't. I don't know if this is something new, but I don't remember hearing it before and I don't think it's something I would have missed. Happens when the Andromedas are plugged in, regardless of whether a source or battery is connected.
