harpo1
- Dec 1, 2014
If you're using the windows app look for the Master subsection of the Album section.I am really new to all of this where do I find the MQA files in tidal?
What if you are using a Mac or iPad?If you're using the windows app look for the Master subsection of the Album section.
Since I don't own Apple stuff I can't say. Try searching the thread I'm sure it's been brought up many times in the past.What if you are using a Mac or iPad?
It seems like you have BUS noise from your computer's USB port, which is common. Perhaps try another USB port on the computer, or a different computer if you have access to one to troubleshoot.
Sorry I think you misunderstand; the sound from my computer is fine with the ASIO drivers, there are just some very faint clicks and pops with the DirectSound and WASAPI drivers which I think might be digital artifacts from the resampling done by Windows. I understand this is unavoidable with DirectSound but my question was I thought WASAPI was meant to be able to output bit-perfect audio, so is there a way to make it do that like the ASIO drivers do? I tried on both MusicBee and Foobar and can't get WASAPI to work perfectly.
My other question was about massive distortion and loud clicks/pops when outputting via USB on my phone. Is there any way to fix this bus noise/artifacts or is there an Android phone that can output perfect audio to Mojo? I have tried every free 'bit-perfect' app available with the same results and I don't want to buy UAPP unless I can be sure that I can actually get decent quality out of a phone.
Apple phones have a reputation for producing a lot of RFI.Sorry I think you misunderstand; the sound from my computer is fine with the ASIO drivers, there are just some very faint clicks and pops with the DirectSound and WASAPI drivers which I think might be digital artifacts from the resampling done by Windows. I understand this is unavoidable with DirectSound but my question was I thought WASAPI was meant to be able to output bit-perfect audio, so is there a way to make it do that like the ASIO drivers do? I tried on both MusicBee and Foobar and can't get WASAPI to work perfectly.
Hi,
I've been using chord mojo with my macbook pro 2013 with no problem.
Now that I switched to a macbook pro 2017 (only USB-C outputs) I have a problem with Tidal exclusive mode.
Playing back with tidal app in exclusive mode gives only crackles and noise. Has anybody experienced this?
Turning exclusive mode off, plays fine but I think I can still hear some pops now and then.
Is it a problem with my cable? I tried two different USB-C male to USB 2 female adapters.
Please, how do you guys hook up mojo to USB-C only macbooks ?
Edit:
Exclusive mode works perfectly with 96khz content (Tidal masters)
but only noise when playing 44.1khz tracks.
Edit2:
Works well in Amarra osx app, although I can not find any exclusive mode there to test.
Only Tidal desktop app 44.1khz gives garbage. Maybe something with buffer sizes?
Thank you, comfortable to know!I think it is a Tidal problem with their current OS X Tidal application. I have a 2014 iMac and have exactly the same problem. It worked fine yesterday or the day before (can't remember for sure which day I was listening to Tidal through the Mojo) and today it sounds like static with the music very low behind it. I have been observing issues with Tidal the last couple of days. Not much help, but at least you know you are not alone.
Stactic with very low music in background is the precise description of how it sounds for me too.
I will mail tidal support.
It’s a known issue with the latest update of Tidal. Really annoying.
Hi,
Edit:
Edit2:
