LouisArmstrong
- Jan 26, 2015
Is AK380 vastly inferior to iPhone + Mojo? How about compared with AK100 + Mojo? I think I should trust Chord more than iRiver. Is this a wise choice?
Who makes that orange bicycle band that holds the mojo neatly against a smartphone?
IPhone =+- AK
X + Y = 1 Banana
X = Y - 1
therefore X = ?
Answers please on a postcard to AK
p.s. they deserve nothing for the crazy prices they charge!!! :wink_face:
The "need" for a dedicated home setup is vastly overrated. As long as you have enough power to drive your headphones it's OK.
Now the thing. Why is this Mojo so famous? Do they apply some sort of DSP effect or equalizer?
Doesn't Rob Watts prefer Optical input for its lack of RF noise. Personally, I find that with capable sources that decode the files well I'm hard pressed to hear a difference between inputs.
Relic, Interesting to hear your views from your first hand experience.
One issue is that optical outputs on Dap's are not that common, AK and maybe the Ibasso DX 80?
From reading this thread and from some pm's - most guys believe that the digital coax input is not as good as the USB input and therefore the benefits of all the hassle of carrying a stack are difficult to weigh up against the simplicity of a decent DAP.
IIRC yes. The Hugo is sensitive to USB noise, more than it ideally should be and I recall that is where his preference came from. I was using it with an Audiophilleo 1 with Pure Power into the coax input of the Hugo for a while, then switched to a Schiit Wyrd instead with much the same level of improvement. The best results from the Hugo I got from a Soundaware D100PRO server via coax. Funnily enough, the Audiophilleo 1 I thought wouldn't benefit from any special USB treatment, but the Schiit Wyrd brought it a bit closer to the Soundaware. With the Mojo I'm just using the Schiit Wyrd and an ALO Audio Green Line USB cable and I felt that none of the above devices that benefitted the Hugo benefit the Mojo at all, even the Soundaware server. The usual disclaimer applies about all this stuff being quite subtle and probably not worth making a fuss over.
@Currawong made a great suggestion in his Mojo review and that's to read @Rob Watts posts to get an understanding of what his goal is when designing a DAC. I'm pretty sure it's anti-DSP. You have to understand that his DACs aren't just off the shelf designs but have taken him 30 years to get to this point. Trying to wrap my head around the technicalities I'm beginning to understand why his DACs are so good but I'm no where near knowledgable enough to explain it. Quite simply, as Chord has stated in this thread, the Mojo is technically thousands of times more capable than off the shelf DACs. Or, to put it another way, it digs deep in to the recording and plays music with all the detail and proper timing for our brains to make good sense of it easily. It's the ease of which the Mojo presents the music that I really like.
