anything specifically you'd rec?
there's also Tannoy, Dynaudio & Genelec actives.
WCDchee... cheers for that KEF info, appreciated.
What about a pair of KEF R100's and a NAD D3020, a nice small setup.
thanks greenbow.
and so the moneysink begins!
the kef x300a is absolutely gorgeous. they're out of my range, but beautiful nonetheless.
if you end up coming across some convincing reviews or any other setups, make sure to post.
i'll hunkering down doing more research; i hope to be pretty thrifty with this purchase if i can.
by the way, what would indicate to me that a speaker is indeed self-amplified/powered? the b&w 685 s2 for instance?
thanks greenbow.
The Kef x300a is good for the price, but bear in mind that the analog input is not a true analog input, it goes through an ADC inside and then goes through the internal DAC once more. Thus, you're really wasting any external dac that's being used, as the conversions to and fro within the x300a will limit sound quality to be on the level of the internal dac. So if you're planning to use the mojo with it there are probably better options out there
Mojo with either my Sennheiser IE800, JH Angie and FAD Piano Forte VIII all sounds great!!!
Please I am curious to know about playing the Mojo while charging. The Mojo manual says this,
"We recommend charging with Mojo switched off.
Charging with Mojo switched on and playing is possible, but the time taken to fully charge will be
considerably longer and depending on volume level and headphone load the battery."
I don't mind how long the Mojo takes to charge while playing. What I need to know is, whether it's successful charging and playing at the same time. This is a deal breaker for me. I intend to use my DAC on desktop quite a lot. In fact my current Meridian Explorer is plugged in all the time to my PC. I see a Mojo doing 90% of it's life on my desktop. (NB I don't mind having to charge the Mojo for taking out and about.)
The concern I have is that I read the unit uses 1.7W while playing. However if I have a 1W charger. I don't see how the unit would charge and play at the same time.
The crux of the matter is this. If I start a day with no charge, can I plug the Mojo in and listen at the same time? Otherwise I literally have to wait four hours for it.
Course you can. No problem. Doing it now. It sounds just ggggreat!
I hope summer never comes back to the UK... There is zero chance of me fitting my triple stack in a jeans pocket
In other news, whilst we're approaching winter in the UK, jacket pocket is a winner
Still baffles me how good a sound you can get out of an MP3 file when having a good enough front end... This set up allows me to go back to some of the hidden depths of my music collection and enjoy
How many watts charger do I need for it then please, to play and charge?
In my case I don't mind if it takes hours and hours to reach full charge while playing. My charger is 1A.
