beardyweirdy
- Jul 1, 2016
Thanks. Any links, I can’t find one
Bought and kept this one, bought and returned this one, both work(ed) great with my Android phone, the POCO F2 PRO.I have just changed my phone to an Android device (usb c). I previously used a Cayin USB C to lightening cable with my iPhone.
Anyone know what the appropriate cable is to connect the mojo 2 to a USB C connection? I guess that a usb C to usb C charging cable will not work ?
I have 2 different length cables from DD Hifi that I bought from their official Aliexpress store. 10cm and 20cmThanks. Any links, I can’t find one
Looks like a nice little cable! Even though my current one works fine, I've placed an order for a straight plug 8cm one, it will work fine with my Qudelix 5K, as well.
Guys was there ever a published chart that correlates output voltages from mojo2 with volume "colors". I've just ordered Pass AmpCamp, that can take no more than 1.6V before clipping, would like to try Mojo in the dac/pre duty with it.
I would appreciate one for my hiby r6 pro + a mojo 2 potentially actuallyIt's taken a while but after many iterations and prototypes the 3D printed case design for the Mojo 2 - Hiby R3 stack is finally ready!
choe-mojo-2-case-for-stacking-with-hiby-r3
The optional transport box for the original Mojo-Hiby R3 case still fits, if the 2 case parts for Mojo 2 and HiBy R3 are sanded to a smooth surface finish. I will be posting a slightly larger version for those who don't want to spend the effort of sanding the case.
Additionally I am working on a design for standalone use of the Mojo 2, and a case for the Mojo 2 - Poly combo.
Should be ready within the next couple of days.
PS: Feel free to PM me if you have questions!
Did you try manual configuration as described in chapter 8?My Poly has randomly stopped working and I don't know anymore what to do. I already uninstalled the Go Figure App, downloaded it again but it stopped to recognize the Poly. What it is possible to do to make it work again?
I tried once but nothing happened. I'll try it again today.Did you try manual configuration as described in chapter 8?
Does the mojo2 sound good with the rognir ?My new choice for portable headphone with the Mojo 2 is, by far, the Ultrasone Signature Pro. I've been through a stack of portable headphones with the Mojo 2 - Liric, Aeon Noire, WP900 - but this pairing is dynamite. Punchy, dynamic, with a balanced tonality and simply outstanding imaging and soundstage. From ambient to black metal, they work across on all genres, digging deep in details and reproducing music with top notch clarity. The fact they're also actually portable with the Mojo2/Hiby fitting in the case, too, is a big bonus. Can't recommend enough!
