Just tested it; very good. Mojo 2 has plenty of power to drive them. Results are dynamic and punchy. Obviously, sounds better when you pair with an amp like the C9 or the Bakoon HPA-01M, but for minimalist set-up, you're good to go. Mojo 2 has the transparency to do the Rognir justice.Does the mojo2 sound good with the rognir ?
Chord Mojo 2 Thread ___ [product released January 31, 2022 -- starting on page 95 of thread]
- Thread starter TheEldestBoy
headmanPL
That's what I use. My Xperia came with a USB c to USB C charging cable. It plays through Mojo 2 without a problem. Always worth checking that whatever app you use to play your music has the ability to output audio directly, rather than pre processed by the phone. The first time I played music using the USB C cable, I couldn't believe how much the sound was altered compare to via Poly hotspotI have just changed my phone to an Android device (usb c). I previously used a Cayin USB C to lightening cable with my iPhone.
Anyone know what the appropriate cable is to connect the mojo 2 to a USB C connection? I guess that a usb C to usb C charging cable will not work ?
Some android phones need the cable to be OTG wired. Otherwise the phone won't switch to host operation.That's what I use. My Xperia came with a USB c to USB C charging cable. It plays through Mojo 2 without a problem.
Neutron and UAPP for sure do, just to name two.Always worth checking that whatever app you use to play your music has the ability to output audio directly, rather than pre processed by the phone. The first time I played music using the USB C cable, I couldn't believe how much the sound was altered compare to via Poly hotspot
Frankly - just about any Android phone (specially without a SIM card) can act as a quality DAP. Just put one of those apps onto it, hey presto, you have a DAP with large screen, good battery life and plenty of storage!
What more one wants!
You can even add streaming services, it has wifi!
Is that wishful thinking or based on something else?Do you, guys, believe that there is going to be a Poly 2, an upgrade, any time soon? Like, next year for example?
My Poly generally works quite well.
I use my Mojo 2 with my computer (MacBook Pro) and my smartphone (iPhone).
The connection between the MBP and the Mojo with a USB C to USB C cable works perfectly.
On the other hand, the connection between the iPhone and the Mojo with a lightning to USB C cable does not work. However, it is indeed a synchronization cable.
I need to use a camera kit adapter with a USB A to micro USB or USB C cable.
Not very practical.
Do you have suggestions for cables that can be used for a direct connection, without an adapter ?
Not very practical.
Look at ddhifi cables.I use my Mojo 2 with my computer (MacBook Pro) and my smartphone (iPhone).
Not very practical.
Thanks, you've experienced these issue too with lightning cable ?
I'm very happy with this one connecting my iPhone 12 mini to Mojo 2:Do you have suggestions for cables that can be used for a direct connection, without an adapter ?
DD ddHiFi MFi06 Light-ning to USB TypeC Data Cable to Connect iOS Devices with USB-C DAC / AMP
No issues with the ddhifi cables.
I've found this :
https://fr.aliexpress.com/item/1005004234740742.html
But kind of short (the same for the MFi06), I like to keep my phone on my hand.
Do you have an idea why an Apple official cable doesn't work while it's designed to a data link ?
I got a lotoo usb c to lighting and stoped working following the latest iPhone update
That’s a thing I was worried about.I got a lotoo usb c to lighting and stoped working following the latest iPhone update
The Apple updates.
Years ago when the OG Mojo came out Fiio did a cable that worked .
Until Apple did a update.
Hence why I bought a ddhifi lightning to usbc adapter.
You can use most usbc otg cables with it.
Unless these cables have a proper Apple chip in them there’s always a risk.
Right, this is a real problem, my Fiio cable doesn’t workThat’s a thing I was worried about.
The Apple updates.
paulrbarnard
- Oct 5, 2010
I had the same issue. I bought a ddhifi and it works perfectly.Right, this is a real problem, my Fiio cable doesn’t work
Total: 31 (members: 8, guests: 23)
