Chord Mojo(1) DAC-amp ☆★►FAQ in 3rd post!◄★☆
Dec 29, 2015 at 9:11 PM Post #7,937 of 42,916
So coax is better then micro usb to micro usb from dc80 to mojo I'm just gonna keep dx80
There is no digital audio output from micro USB with the DX80, which has been mentioned a few times. Optical or coaxial only. According to the iBasso specs on their website they both output 24/192.
Dec 29, 2015 at 9:12 PM Post #7,938 of 42,916
Then which DAC is in play? The Fostex or the Mojo?
It would be the Mojo as the Fostex is connected with optical. In this case the Fostex is required to get the digital signal out from the iPod classic and then it's simply passing it on to the Mojo.
Dec 29, 2015 at 9:16 PM Post #7,939 of 42,916
Less interesting than the SR-009 and Mojo combo but a tad more pocketable.
Dec 29, 2015 at 9:17 PM Post #7,940 of 42,916
Hello there. Again.
So this is one way to get a digital signal out of a iPod Classic. That's interesting as I didn't know I could do that with my iPod Classics. What other (hopefully cheaper) way is there to do this?
Cheers
Dec 29, 2015 at 9:18 PM Post #7,941 of 42,916
Hello there. Again.
Cheers
I don't think there is one....... :confused:
There is the Cypher Labs option as well, but I don't know about cheaper...
Dec 29, 2015 at 11:03 PM Post #7,945 of 42,916
Anyone else find themselves preferring 24/192 over DSD with the mojo? Comparing both with the same album, 24/192 seems to sound better.
Dec 29, 2015 at 11:27 PM Post #7,946 of 42,916
Do they have the exact same mastering? Because if not then you're not comparing formats, only the mastering.
Dec 29, 2015 at 11:39 PM Post #7,948 of 42,916
Are you ABX blind testing for your comparison? Or could it be placebo effect?
Dec 29, 2015 at 11:41 PM Post #7,949 of 42,916
Not abx but I'm closing my eyes and repeating certain parts over and over and can tell differences, seem to be mostly in dynamic range. DSD sounds like the bass extends less, the stage is smaller and the treble is more subdued.
Dec 30, 2015 at 12:04 AM Post #7,950 of 42,916
This reviewer seemed to prefer the Fiio X7 compared to the mojo with DSD playback. Does anyone else have a comparison?
http://youtu.be/Nev7BYpYUfc
