I previously commented on how I loved everything about the mojo except the soundstaging.
I am Glad to say that I would like to take that back. The first Two times I tried it, it was congested, not much sense of air and space. The third time i tried it, decided to give it another go and boy am I Glad I did. The first Two, I didn't have a proper coaxial cable in hand and simply used a 3.5mm interconnect. This time I had a proper coaxial cable to compare with.
The difference is astounding. It is way bigger than any cable differences I have experienced and mind you, it was a basic Belden wire which would have cost 2 dollars a meter at most. It was nothing fanciful.
I know people might be skeptical of cable differences, but with regards to digital cables, I understand that the 75ohm cable requirement for coaxial is not merely snake oil. It is actually something that is taught in the classical engineering school, not simply hifi mumbo jumbo snake oil. It's got something to do with transmission line theories and what not and how an improper resistivity would bring about signal loss due to the creation of certain filters, at least that's what I was told by proper Engineers. I won't go into too much detail as I am not well versed in this area. But whoever out there is using an analog cable, please try a proper digital cable. The resolution, transparency, and staging and spatial cue reproduction takes a huge huge leap.
While previously I mentioned the improvement of the mojo with amping, I am now Glad to say that I prefer it unamped by a portable amp. The staging opens up more yes that is true, but as someone else pointed out, the finesse, the resolution, absolutely suffers. This is even with my Favourite pure 2 amplifier. And now, the staging is open and airy enough that I don't feel The need to boost it with the pure 2.
