georgelai57
- Jan 5, 2012
What is the difference between co-axial and a 3.5 mm interconnect? It can be just the ohms required, can it? Are they wired the same?
Mojo actually has three independant thermal cut outs a special high temperature battery and very sophisticated charging circuitry . Picking up on an earlier post Mojo actually does not dissipate a lot of heat when it's working. It's only about 1.7 watts and when it's charging it adds about another watt so its not much really. However the electronics and battery are thermally bonded to the aluminium case. The Mojo's case can only shed its heat through convection or by radiating it away. This can only work if there is a temperature differential between itself and its ambient surroundings if there is an insufficient gradient between them, the Mojos temperature will rise until there is a large enough difference to pass its heat to the air surrounding it.
If it is prevented from doing this perhaps by being insulated I some way it's temperature will rise until one of the three shut down trips operate. note the battery is safe to 150 degrees and the trips all operate up too a hundred degrees lower. Therefore it's perfectly safe. In fact if it's feeling mildly hot at first to your hand. Your hand alone will easily soon bring the unit down to a reasonable temperature.
Hi
I've just picked up a Mojo and have to say I think it really is a miracle of engineering to produce such sound quality from a tiny box (I was amazed how small it was when I opened the box) it really has made an amazing difference to my full size cans (HD700 and HE400i)
I however have a query regarding DSD files, according to the box and manual the button should glow white when playing DSD files however mine seems to glow the light pink colour which is supposed to indicate 768khz this is from iPod touch using Onkyo HD player, anyone else noticed this or have any ideas why ?
Thanks, Carl
Sennheiser HD600s. Hope to try some HD800s soon.
Okay, tell me the truth - is the Mojo a better sounding device - and a smarter investment - than an ak240? (Given I could add any old player (like the ak100 or the x3ii) for source). Cause I'm getting second thoughts here - I was supposed to get a 240, but now it looks like the game has changed...
Would be using it with Angie or Dita The Answer Truth Edition.
Personally, I think the Mojo sounds better than any of the AK players including the 240 and the 380 even with the external amp.
I'm driving my Mojo with an old AK120 (since it has two storage slots) and am extremely happy with it sound-quality wise. If I didn't already have the 120 I'd likely have snagged one of the AK100 TTVJ was selling for $375, since it's a better fit if you stack them.
