jarnopp
- Nov 26, 2014
you'll never get better sound through adding extra amp. Just like you'll never get better sound through a recorded music compared to hearing it live in person. Another source added (whatever it may be) is another degration. You'll never get better picture through a plasma, oled, or ips, as seeing it live. all the same.
I don't know that this is correct. Wouldn't that be equivalent to saying you won't get better sound using an amp (any amp) after your preamp? However, if your preamp is not capable of driving your speakers, then fine, but most are probably not. That means you will always be better served b getting enough power to drive your speakers by using an amplifier if your preamp cannot do it (and for which it was not intended).
I understand that Rob and John feel the Mojo can drive virtually any headphone adequately, which would be great. In practice, it will be up to the listener to determine whether the Mojo sounds best with their setup on its own or with an amp.
I will say that I totally respect the design philosophy that says "we have taken this approach and believe this is the best way" and the passion and engineering behind it. I will always go for this over the "designed by committee to be unoffending and the 80% solution" because it will give you the single malt rather than the blend. Your job to determine if it's right for you and your system. From a product perspective, I want the ultimate expression of the designers' views. But, that doesn't mean my implementation will be the same as the designers' in all cases.
All theoretical, thought, for me, as I do not have my Mojo (yet), Liquid Carbon (yet) nor Dharma d1000 (seriously considering). I expect there will be folks with that chain and anxiously awaiting impressions...
