vlach
If you are connecting from your PC to the Mojo, consider going optical. It removes any hint of RFI.
I have no issues using USB.
How is it connected to the source? It sounds like it is either losing the sync or maybe RFI, if you have a cell phone too close?Well, now my new chargeable Mojo is behaving oddly.
I have it in line out mode connected to my stereo and to my Desktop amplifier.
Sometimes out of nowhere in anything I'm playing, it will start making a horrible static noise and just lose signal entirely. Rebooting it will often fix the issue, as will pausing and unpausing the audio a few times.
Is there something I ought to do to prevent this? Some unknown mode I can run it in? I can't really replace my PC or motherboard because the DAC doesn't like it.
Well the xDuoo X10T II has arrived and I have had a very hard time keeping the Mojo off. I am smitten, enchanted, enamored. I am in love. The sound quality is absolutely sublime. I now realize that Mojo is easily one of the best DACs I've ever owned.
Don't have a cable that will connect the xDuoo to the Mojo optical input, but the coax is just perfect. The microdetails and transients, the blackness of the background, the subtlety, all just incredible. I was also able to get this unit working as a USB-TO-SPDIF converter with my phone/UAPP as a USB source.
If anyone is like me and always having some degree of nervosa over finding a proper transport to get the most out of Mojo, I enthusiastically recommend the xDuoo X10T II. Perfection *chef kiss*
Some dealers advertise the service, for example https://www.audiosanctuary.co.uk/chord-mojo-replacement-battery-service.htmlHow much is a decent replacement battery and where can I source one? Thanks.
Will be putting my Mojo up for sale when I get home.
I think audiosanctuary are pricing that replacement battery service almost 'at cost', so the price of the certified replacement battery is only slightly cheaper.
Google 'chord mojo replacement battery' and plenty of links/videos are listed.
Beware the 'service centres' that try and charge an extra $250 just to fit the battery (which takes just 5 minutes).
Email support@chordelectronics.co.uk for advice, because Chord has been able to ship batteries to specific dealers in the past.
Thanks a lot for the good info! I have to decide whether it's worth spending 77 GBP + shipping or to sell the Mojo noting the dead battery. I'm not sure what will make financial sense. I can also check with my local shop to see how much the battery costs alone.
Out of curiosity, may I ask what has prompted you to sell it? It sounds like you are still travelling. Did you find a better portable unit?
If it's too loud, why not turn down the volume?Need help
Trying to connect N3 with chord mojo with usbc coax cable
When playing a song on N3, Getting very high levels of output from headphones connected to mojo. Such a high sound output can surely destroy headphones as well as eardrums. Is something need to be done within the N3 settings?
I have the xDuoo X10T II, and tested the stock coaxial, and a silver coaxial (better than stock by a big margin), and Glass fiber Toslink. The Toslink was superior to both the stock coax, and the silver coax. I am certain whatever Chord product is in my future, Silver Coax or Glass Fiber optical will be my choice. I have a poly also, and the XDuoo is far superior in SQ.
