Chord Mojo(1) DAC-amp ☆★►FAQ in 3rd post!◄★☆
Sep 5, 2020 at 2:35 PM Post #40,531 of 42,916
Nope you only plug the cable. And boom it's all
Thanks! I'll get a similar cable to try it out.
Although the Hiby music app is very useful, I find on the R5 that the USB Audio Pro app delivers noticeably higher audio quality with either native device playback or external streaming.
USB Audio Pro app = UAPP?
Sep 5, 2020 at 8:02 PM Post #40,532 of 42,916
Sep 6, 2020 at 5:11 PM Post #40,533 of 42,916
Could anyone recommend an USB-C to micro USB cable that I can use to connect my Samsung Galaxy S10+ to Mojo and use Mojo as an USB DAC? Thanks in advance!
Sep 6, 2020 at 5:14 PM Post #40,534 of 42,916
Sep 8, 2020 at 11:22 AM Post #40,538 of 42,916
Anyone here got experience with driving the LCD-X ( or other ( audeze ) planars ) through the mojo?
I know it's probably not ideal just wondering
I was using a mojo with a LCD xc on daily basis at the office before covid thing.
Sep 8, 2020 at 11:51 AM Post #40,540 of 42,916
Ah and it made the Xs sing?
Note it was XC not X.
It was ok, not perfect but definitely good experience - I liked this combination for acoustic music very much !
XC has a bit edgy harsh treble which Mojo helps to tamed down a bit.
XC as it's closed headphone can sound congested at times, sound stage is not particularity wide.
Mojo has similar sound signature ,a bit closed not wide, so sometimes combination of both lacked openness, air - it wasn't a perfect match.
But with a LCD X since they are open it could be a different story.
I tried a LCD X many times and for me they were better than XC - but never heard LCD X out of the Mojo.
Sep 8, 2020 at 11:59 AM Post #40,541 of 42,916
But with a LCD X since they are opened it could be a different story.
I'll find out soon enough. But of course I don't see myself wearing the X outside anyway.
Hmm how would you describe the sound of the mojo apart from having a slightly closed-in signature?
Sep 8, 2020 at 11:55 PM Post #40,543 of 42,916
Been using the Mojo with my LCD-X for over two years now. It’s a great combo that you can listen to for hours on end as it’s never fatiguing. LCD-X is relatively easy to drive, and Mojo has plenty of power, so bass slam and extension are also excellent.
Sep 9, 2020 at 2:24 AM Post #40,544 of 42,916
As I said compared to other Chord dacs a Mojo is a bit "closed" sounding.
Mojo energy focuses on mid/high bass and mids. It's not like it's bumped or something but thats the frequencies that Mojo focuses and let's say builds its presentation on.
Highs are just slightly but only slightly rolled off (I really didn't want to say rolled off - but definitely not extended as other Chord dacs)
The strongest point of the Mojo for me is mids/vocals region reminds me Chord Hugo TT (1st) in this regard.
Sep 9, 2020 at 4:36 PM Post #40,545 of 42,916
I’m using the Audeze EL-8 closed back with my Mojo. Getting decent volume between the green and blue level. As one might expect it’s rather closed sounding but closed backs are a necessity when one is listening in public spaces where I tend to use this combo,
