x RELIC x
@17Daggers, if the lights change colour from your previous volume setting while holding the buttons on power-up then it’s going in to line-level mode and there is no other preset besides 3V. Because the colours aren’t exactly the same as the manual states doesn’t mean that it’s not going in to line-level mode. Chord uses a mix of RGB LEDs and it may show slightly different from the expected colour stated in the manual.
Regarding your speakers distorting it’s likely that 3V is too ‘hot’ for their input as most amps expect a 2V input, which it seems you’ve already guessed. To get close to 2V set the Mojo in line-level mode and then click the volume minus button 4 times. This will get you to 1.9V which should be ok for your powered speakers. The line-level mode is nothing more than a volume preset that’s forgotten with a power cycle so don’t worry about losing any quality by doing this. ALSO, PLEASE REMEMBER that this setting will remain in your next power cycle, unlike the line-level setting, so please use caution if you connect headphones/IEMs with the volume at this level.
