Wheel Hoss
How does Mojo pair with Campfire Cascades?
Prefer bass/warmth to my SS
I tested the Aeon Flow closed and found them a tad bright. I know I won't be popular saying it, but I recommend the Nightowl.
I’m thinking about getting a new pair of closed back headphones to use with mojo in work... considering aeon flow closed, anyone out there who can say what they pair like?
It is very interesting that you raise that point about longer listening. It was the Sound Science forum which led me to blind testing. I was and remain sceptical of my ability to detect small differences in sound. There may well have been a defective part of the test equipment. Me! I felt right from the get go that the Mojo reveals itself over time. SS will have none of it. I still prefer listening to music through Mojo. Even since failing the blind test.
I actually can’t listen to the Nightowl’s (edit: I mean Nighthawks, haven’t heard the Nightowls) anymore. Even with the HM5 pads. So many way better headphones (distortion measurements aside).
You will need a cable to connect to your digital source, and a Phone charger with micro USB connector.Getting this soon. Does it come with any cables or batteries? If not, what do I need? Thanks!
I think the reason they sound a bit muffled and dark when coming from another phone, is because of extremely little grain of the sound, which makes everything sound smooth as butter. Some interpret that as a veil and lack of sparkle, but it's not. The same as the HD 650, but apparantly the Nighthawks have even less grain, which makes that effect more noticable.I did
I have both the NightHawk and NightOwl. The Owl has a similar base character but more detailed bass and more treble energy.
They are both kind of unusual IMO, they sound a bit muffled and dark when coming from another phone, but when I dive into the sound and adjust to it it’s a really musical experience. I really like them still.
Had the Mojo for about 2 weeks, predominately using it with my iphone. Any recommendations on a transport / player to pair with the mojo, looking for something that can do tidal offline and has 1 or 2 micro sd slots since I have a few hundred gigs of lossless music. Given the Mojo is doing all the work, hoping there are some decent options out there that don't break the bank.
If the Nighthawks would have an adjustable headband, I would've gotten them.
Yes, even though I've not heard them, I suspect that's why there are so many conflicting opinions about them.That is a very interesting take on the NightHawks! I have been listening a lot with IEMs in the recent weeks and months, have to go back to listen to the Hawks and Owls a bit more again.
Thanks. Any recommendations for an android phone. I have been an iPhone user for years. Also need support for lossless Alac and flac?
