jarnopp
- Nov 26, 2014
Thanks ! will try to dig into these battery failure reports. To be honest I looked at the Mojo because of the price. Not willing to put 1500 or 2000 in a DAC.
Compared to my Pioneer DAP or on top of it, should I expect much better quality as well? Or should I just stick to the DAP?
I would stand behind the thinking that you will get much better SQ. Mojo has been the best purchase in 35 years of this hobby. Also, if you will only need in a home system and not for portability, you can save some money by finding a used Mojo and removing the battery. They are reported (even by the designer) to work plugged in without the battery, and the output should be fine feeding an amplifier.
