jmills8
Previously known as bmiamihk, jmills2
not me but I know from FB.you the one with Rudi right?
I would probably put some sealant on it so that it doesn't Oxidize... but some people like the look of that on copper (not me though)... I'm sure it will oxidize quickly with the oils from the hands.
Give them a few months and they will turn green
That will definately count as a mod.
Doesn't the green oxidization require salt? Not sure. Which I guess could come from your fingers/hands anyway. Yes, clear coat makes sense.
Before I experiment more, thoughts on how to eliminate hum in this sort of set up? Have folks successfully connected their Mojo directly to a power amp in a 2 channel setup?
As an interim step until I get my Hugo 2, I'm trying to connect my Mojo directly to my Classe CT2300 amp (-> B&W 802 speakers) via the single ended RCA inputs on the Classe. When I go through my Oppo HA-1 as a preamp (Mojo headphone out to RCA in on Oppo to RCA out to Classe), everything is hunky dory. When I try to connect the Mojo directly to the amp (Mojo headphone out to Classe RCA single ended in), I get a horrific hum.
My ultimate plan is to have the Hugo 2 connected directly to the amp (via RCA outs), so I'm trying to simplify my signal path in anticipation of that (and hopefully avoid similar hum issues with the H2)
key points:
desktop>Mojo is via optical, so no electrical connection
Mojo is running off battery, so no mains electricity connection
So only the amplifier is connected to ground, so no ground loop.
Can you try connecting the Mojo directly to your amp, and remove your HA-1 as the potential issue - for this test?
Probably trial and error is needed, to narrow down the root cause.
Thanks for the quick reply guys.
I should clarify that "horrific" for my hum means I'm worried that it will blow my speakers (extremely loud).
I have the same issue when connecting the mojo on battery only (not connected to power and not connected to any other source) to the amp. Strangely, I also get a significant hum when connected to the Mojo with the Mojo power off and nothing else connected to the (with multiple different cables/adapters)
I have had zero issues with the Mojo driving headphones/CIEMs/Oppo HA-1 as a preamp/etc.
I just tried connecting my amp directly to my Pono (headphone out, power off) and got the same hum as the Mojo. Per @Hooster the problem may be with my amp. I'll experiment there.
Thanks again
Ok, so... I sent back the Shanling M1. I thought it was nice and all, but didn't like having to reach around and continually grab the jog wheel for play pause, etc. So. I'm on the hunt again for something "like" the M1, isn't much bigger than the Mojo and can do the BT 4.0/Aptx streaming, and hopefully has Coax/or USB out. Physical buttons are a BIG plus as I want to operate it with the screen off. Touch-screen is not a necessity. Any ideas? I'm leaning towards Cayin N3. I'm currently using my Sony Xperia Z3v as a DAP for the Mojo, but that phone is quite a bit bigger than the Mojo (so stacking looks silly). Any suggestions appreciated.
Hidizs AP60?
I just stumbled onto that... It looks excellent! I think the buttons are capacitive... so I'll have to read a bit more about it.
Thanks for the suggestion!
I have both AP60 and M1 and tested both with Mojo, M1 is much much cleaner and gives bigger soundstage Give the AP60 to my son. Just ordered yesterday the Cayin N3 to use it with the Mojo, don't know if it will sounds better than M1 with Mojo.
Also, I'm wondering if coaxial sounds better than USB on the Mojo when needed with DAP.....with the Cayin N3 I ordered the ''special'' usb c to coax cable....hope will sound good!!!
Anyone test usb vs coax on Mojo?
