iamhanin
- Mar 5, 2017
So how come the power buttons light changes when i up the bit rate
I need more details. Tell me exactly what you're doing.
1)downloaded the driver.
2) install the driver
3)choose digital output(chord Async usb 44.1khz-768khz) for my playback.
power button always stays red. all my music are 320mp3.
last night just for the heck of it i started to play with bit rate in PC and noticed the color changed accordingly.
Hello, you have reached Chord fan support. This post may be monitored and/or recorded for quality assurance.
I think you meant sample rate, not bit rate. Which player are you using? You did not specify that you are using ASIO, so I'd recommend that as your next step. You can configure Chord as the device in the output mode without it being bit-perfect, and I suspect this is the issue.
I cannot express how grateful I am for the help! I am too old and new at the same time
I am using Foobar2000
Forget about the filters. The real issue is that one of the best headphones on the planet, the HEK V2 may not be driven to its full dynamic potential by the internal amplifier of the Hugo 2 and since the RCA line out is not direct from the DAC any amplifier added to the chain will cause significant perturbations/distortion (as per Rob). I am now thinking that a different DAC with a true line out makes more sense to pair with the HEK V2 so that a really good headphone amp can be used. I am not a fan of the Utopia as it just doesn't have the air and open live 3D experience that the HEKV2 has.
Okay, in foobar2000, click File, Preferences, Output, and select "ASIO : ASIO Chord 1.05" under Device.
under preferences, I get component-display-keyboard shortcuts-Media Library-Networking-Playback-shell integration-tools-Advanced.
no out put
It's the poly attached to mojo?
Edit:extended kit. Whatis this?
Moho not big enough so add an end to make it bigger pack.
