x RELIC x
Any way of using mojo with ps4?
Optical TOSlink.
Edit: Unless it's the PS4 Slim, which they neutered the Optical TOSlink connection.
I use 3V line level with my Genelec speakers daily. Never tried 2V. May be i will do some testing today !
2Vrms for 0dBFS is the redbook standard. I'm frankly not sure why the 3V was chosen in the Mojo.
On the back of my Genelecs (1030's) you can alter the input sensitivity up to +6dBu. But I don't know if that means that for higher input levels it will clip. If it did, you for sure would have heard it already as 3Vrms is much higher than 6dBu.
When I hooked up my Mojo to my O2 amp it was clipping quite noticeably in it's standard 3Vrms config, but setting it to 2V solved that.
EDIT: Spelling
I will surely check tonight !
How many clicks i have to go behind after 3V line level and which color will the light ?
3 clicks down -> 2.1 Vrms
4 clicks down -> 1.9 Vrms
Cheers
So i have to click 3.5 clicks to get 2V rms
Wait, but how are you actually setting your listening level in this case? I'm assuming your Genelecs are like mine and don't have a "volume" control.
You're much better off setting your source (whatever that is) to max (digital) level and controlling your listening level on the Mojo using the volume buttons. That will give you the highest fidelity.
Did the mojo hurt your hand? On the go means walking for 10 mins? ☺
Im a coach in Hong Kong. I am walking, jumping on many trains, buses, taxis and on Fridays a ferry aswell.my daily commute is 3 hrs everyday of the week. No days off with a back pack (filled with equipment) phone and mojo with its phone. I also take my hugo and phone.Commute for me is 45min in bus/underground and walking.
No the mojo didn't hurt my hand, I just don't find convenient to bring the stack around. I would prefer to have all in one device.
I guess it's a personal preference right?
just saying if a 51 year old can carry a mojo all day then another can. But if you cant or dont want to thats your choice.Not sure what you mean with this but hey, whatever floats your boat, as they say!
