Guys, help me out here.
I got the Mojo last week but I was really disappointed. The Mojo should be called the "Bassline killer", it completed trashed my entire music collection.
I can only hear music with Bassline, Drums, Kick (percussion type instrumentals,etc). My ears are completely incompatible with acoustic music. Guitars, Violins, Pianos and all those types of instruments cause massive distortion in my ears irrelevant of the audio equipment I have, low res or high res, Mojo included.
First I tried the Mojo with my B&W P7 and it's literally the worst thing I've heard in my life. The Mojo completely destroyed the amazing bass impact and bass line of the P7 and yet the Mids never showed up. It feels like a big chuck of the frequency spectrum is missing (Lows and Mids). Because the Mojo also tames the highs it's even worst, half of my music sounds almost like mono with the Mojo+P7, atrocious really, you have to hear it to believe how monophonic, dark and hideous it sounds.
I was about to give up on the Mojo but for some reason decided to try my old and trusty HD25 II with brand new velour pads and holly cow, what a massive change for the better!!!! Although the HD25 have very crude ear piercing Mids and Highs it was like going from Mono to full blown Stereo, sometimes even 3D like. All of a sudden hundreds of new beautiful stereophonic sounds popped up out of nowhere, sounds that are nowhere to be seen with the P7. I thought to myself, "so, this is what the mojo really sounds like, damn!!"
The only problem? Although everything else sounds a thousand times better with the HD25, there is still no bass, no Bassline, and no Kick impact with 99% of of my tracks that are known for having powerful impactful bass and very forward Bassline.
I fixed this in some way by getting the Real Bass Exciter plugin for Foobar.
Settings:
Threshold Frequency: 550Hz-700hz (Depends on Music)
Harmonic Frequency: 45Hz
Harmonic Bandwidth: 50Hz
Harmonic Energy: 24-30dB (Depends on Music)
Above Pre-Wave Decay: -92dB
Below Pre-Wave Decay: -11dB
Now, this completely changed everything. My HD25 now sound better than when I was Djeing with them back in the day. Even though the Kick is still not where I want it to be now I can feel that really tight and impactful kick without ever bleeding into the other frequencies (great!). Unfortunately I can not raise the Harmonic energy further to create more Bass impact because the sound starts to get horrible and distorted after 30dB. I realized I either need a more compatible pair of headphones with the Mojo or an AMP with Bass gain, maybe the Cayin C5?
So, this is where I need your help to choose either Heaphones or an AMP. Something tells me an AMP would be better because If the Mojo took out all the Bass from the HD25 and P7 it will probably remove the Bass from every other headphone.
(((( Hope not!!
Anyway, can you Mojo owners test the following tracks yourselves with your headphones or amps to see what pairs better with it?
This one is masterfully produced and it's one of the few tracks I have where I can hear the kick impact without EQ. Only problem? The kick instead of sounding Pum, Pum, Pum like it's supposed to sounds a bit like Pock, Pock, Pock (kind of hallow but nothing major). Can you test it with your headphone or amp with bass gain to see if it sounds fuller/more fun?
This one is missing kick impact and sounds too metallic and kind of hollow (need a bit fuller sound and obvious kick impact)
This one is missing the Bassline and Kick again, should sound fuller.
Same problem with this one, too weak of a bassline and kick, specially when there are lots of others sounds. Most of my music collection sound like this one. The Mojo puts all the secondary sounds in spotlight at the expense of kick and baseline and this should never happen as the Bassline is the engine & rhythm of the music and without it all you have is an incoherent soup of sounds.
Just one note: Take into account these are compressed youtube versions of the tracks and they have more bass than the original files because of compression. Spotify is the same, actually even worst, all the tracks seem to have gone through a compressor.
I'm really hopping headphones like the Audeze Sine or maybe even the Meze 99 Classics (cheaper) which are considered fun and engaging work with the Mojo. Or Maybe even the Cayin C5 AMP or similar. But if someone tells me his headphones/amp don't have that much better bass but instead they have insane instrument separation and 3D type sound where you can almost reach and touch the sounds I will not know what to do.lol I would like to have them both, the tight bass/kick impact and the full on 3D sound, regardless of how big the sound stage is. My Fischer Audio DB02 MkII has one of the tiniest soundstages yet when properly Equalized it's full on 3D with superb instrument separation so I could care less about big sound stage at this stage.
Almost looks like I'm asking for Headphones or AMPs that sound like LSD. =D Actually deep down I think I am. =))))) I actually had a eur4000 car audio setup that sounded like it, hehe.
Appreciate your help guys. Heck, maybe we could even start a thread about Mojo + EDM heaphones so that people don't end up in the same situation where I am at, with a brand new B&W P7 which is completely useless with the Mojo for my music collection.
take care
