StryGR
- Feb 15, 2014
My setup for reproducing Tidal music...
It works perfectly!
It works perfectly!
It works perfectly!
I ordered the Sys Concept cable...thanks to you all for the suggestions.
Anyone stacking a Mojo with 120ii are you using bands or o-rings or what?
That is funny.here's a left-field choice of transport for the purist who don't need album-art etc. the Sony PCM-M10 (£150+ new), has a good form-factor for the Mojo... there is a higher spec on it's big brother but that's got bunny-ears, both on links below:-
PCM-M10: http://www.sony.co.uk/pro/product/broadcast-products-professional-audio-portable/pcm-m10/overview/
PCM-D100 hi-res: http://www.sony.co.uk/pro/product/broadcast-products-professional-audio-portable/pcm-d100/overview/
Got the Mojo yesterday. The first optical cable I tried lasted for about 10 minutes before it died completely. Today, I'm using a better one and it works fine from all my DAPs from A&K. Sony A17 works fine with the very expensive ($38) and hard to find Walkman to USB audio cable. I have about 7 devices with coax output and each one has a slightly different cable (none 3.5mm to 3.5mm), so I'm still searching for a combo that works. USB from Windows 10 works great.
Ordered a few short optical and USB cables to make life easier.
