jmills8
Previously known as bmiamihk, jmills2
that htc has C Type usb ?No idea I'm afraid but I've also tried another phone I have and it's the same thing.
Yes sir. So, not sure about that theory then. Maybe you can take some close ups and send it to chord? Sorry, out or suggestions for you. Mine are scratched as well but I never thought it was bad.
Startech are cheap and work fine , that's what I'm using at the moment - although I'd be happy to trial any other more expensive cables to see if there was a remarkable difference between the 2
Plus you'd probably void your warranty as well. I have to inspect mine more, but I don't believe I have any scratches such as yours.
I'm not so worried about the warranty. Any manufacturing defects would have shown up long ago.
You guys better stop scratching those balls
On a more serious note, I think USB cables don't matter much in the 10cm range as long as they're not faulty. Picking up wi-fi interference from my DP-X1 with any cable, even when using the ferrite bead. No big deal for me as I use the stack in offline mode, including Tidal. Hit that stand-alone button on the DAP and you get pitch black background!
Best thing about the Mojo extension, along with making it more "stackable", is the fact that is protecting the USB ports. No risk of damaging Mojo's USB ports when the unit is in a pocket somewhere and no plugging-unplugging to charge or stack. Brilliant!
Thinking of getting the chord mojo so was looking around for cases too.
Does anyone have both the official Chord case as well as the Dignis case?
How do the 2 cases compare?
Also found this $40 USD Dignis clone from China:
USB cable does matter.
Just take any OTG cable, pure silver and do a AB testing with your stock cables.. and you will get your answer..
I have tested so many cables with my Mojo, a long back.!!
Sound stage, increase bass, increase top end.What sort of differences do you perceive?
My favorite answer is "warmer"... As if switching from copper to silver somehow performs an FFT, increases some frequency bins, then performs an IFFT... All instantaneously and without actually buffering enough samples to do it, with no processing or active components and zero power.
