- Feb 11, 2008
Perhaps it is faulty; perhaps there is some other reason. It is not helpful to immediately return it without doing a little exploration, first, or the situation may continue with a replacement unit.
I need some advice. Got a mojo on Friday, so far works fine by optical into ak120 but when I try to connect it to my android phone (htc10) it doesn't work. I get a quick flash of light on the mojo but that's it. The phone only registers the mojo as a charging device. Any ideas? Thanks in advance!
Did you use the correct USB port on the Mojo?
I was referring to the guy with the gouges in the chassis next to the "volume down" ball.
I plug the mojo and the phone together. The power light on the mojo flashes for a second and then goes off. The phone itself only registers the USb connection as being able to charge from, no other options.
Definitely.
My other device is a wileyfox, that also does nothing.
Ah, apologies - next time, please take the time to quote who you are responding to
I would back that also.Will do, nested direct quotes are great!
OK mojo is now lit up. The power ball is blue and its plugged into my htc10. The USb options are still only tp use as power. Do I need a specific app to make it work for audio?
