Tadamn
- Jun 30, 2016
So guys any further thoughts on this? AKG 3003 or EX1000 as a best buddy for the Mojo?
I myself use N7 Player.That's a lot of players... So which one do you really use?
My budget only allows me to choose between ex1000 or akg. I really don't see any point for my needs anyway to spend more than 400gbp on an iem which is what these cost.
I have just being trying to get the Mojo to work on a manual input selection in my PC settings. Not happening though.
I have my PC on the USB input, and a DAB tuner on the optical input. It means that every time I have the PC on, I have to remove the USB cable to have the tuner on. USB being the default number one input selection.
My worry is that eventually I may damage the USB input on the Mojo, from unplugging and plugging. I mean I don't do it often at all, but it does worry me. Plus it's a hassle, and the USB input is miniscule.
I tried leaving the optical cable in from the DAB tuner, then disabling the Chord Mojo from the PC. However the Mojo still shows the input signal from the PC on the power button. Therefor no sound from the tuner.
Please does anyone have any ideas?
Then again... we will eventually see an SD-reader module, which will make things rather interesting, to say the least!
SD-reader module...Do you mean we should turn head towards Chord?
Rgds.
Now back to your issue. In order to deselect USB selection you need to remove the 5V from USB computer port It is how Mojo is selecting it ( once connected). Then you may, by software settings, remove your USB port. I didn't try it yet.
