yoghurtlidlicker
- Nov 22, 2008
It just doesn't change/adjust sampling rate.
all sorted now.
Sure!
1)The Wyrd4Sound Recovery helps to clean and re-clock the digital stream being fed to the Mojo with the use of a Femto clock. I find the Recovery to add a bit of immediacy to the leading edges in my music.
Question.. what are the best mini-USB to Lightning connector options right now?
Great tip -- just bought it and used it, and worked flawlessly on the new Radiohead. Thanks!
Thank you! You might be right about the Recovery adding a perceived something. According to John from DAR Audio it adds "jump" factor.
correctQuick question....
When Mojo is fully charged the led should turn off, right?
it's been 5h and still on, not blinking though.
I'm using 2A charger.
Quick question....
