miketlse
- May 8, 2016
thanks for the suggestion, I will however try some cables first to see if they make a difference
Ok, they will be the cheaper option if they solve your issue.
I find my android phone + Spotify via usb very very good compared with uapp, clics and poor sound...
Is there anything better at the 600$ price point for desktop use than the MoJo?
Would use it with Ether C and HD600
I tried connecting my HTC 10 directly to Mojo without OTG cable.
And its works , but the Mojo keep showing BLUE color as it receive 192K even when I play 44K
Roscoe, what do you think of the Mojo/KSE1500 combination?
LOVE IT. I haven't swapped in and out a bunch of DACs or DAPs, but this combo is the best that the 1500s have sounded (not terribly surprisingly).
Other sources used: LG V10 (ESS DAC), GeekOut 400, Schiit Fulla. So again, not surprising that Mojo is best of the bunch. But Mojo was also recommended by 1500 owners who've tried many more highend sources with them.
I don't get it, mojo sounds so awesome from my imac -> (cheap amazon) optical cable -> Oriolus IEM or Senn HD800 .... but when I want to be portable and switch to my android phone with UAPP and usb-cable the sound is just different (worse!)... I don't get any RF noise or glitches, it is just that the soundstage is smaller, the sound is not as clear, midrange seems more recessed etc....
How is that possible with a digital data transfer? hmm... such a mystery... When I listen from my phone the mojo-magic is just not there.... then on the imac... bam! all the mojo-magic is back!
I am thinking of buying an AK100 as a source now as I think the optical connection might be just better than usb... does anybody has a comparison with it and other sources, maybe imac through optical? Hope the AK100 is as good as the imac
Ican speak for either of these cables, but I found them looking for a plausible way to eliminate the Apple CCK connection cable between the Chord Mojo & my iPhone 6s Plus! One apparently/obvious has the CCK cable embedded, and the other does have the CCK have it in the cable at all. Your guess is as good as mine on the absence of the CCK chip?
1. Chip: http://penonaudio.com/Lightning-Pure-Silver-Decoding-Cable
2. No Chip: http://www.ebay.com/itm/Pure-Solid-Silver-Lightning-to-Chord-Hugo-Mojo-interconnect-cable-Iphone-4-5-6-/172158889773?hash=item2815782f2d:g:WOsAAOSwYIhWhPFU
If you aren't getting good sound, very likely the software is up-sampling. Be careful that if you aren't using software that is setting the sample rate to match the music that this isn't happening. You can check the rate the Mojo is receiving by the color of the power button. If you're listening to a 44.1k file and the Mojo isn't showing a red light, then your computer or phone is up-sampling. By default OSX will send at the highest rate that the DAC can take through the connection used (except if using optical). That will sound bad for sure.
Both are hacks of the Lightning CCK. You cannot use the Mojo from an iPhone without the CCK chip in the cable.
I have a question about the bolded part. When I connect a dac to my mac, it automatically chooses max settings possible resolution wise. I was switching back and forth between max settings and 16/44 and I could swear the 16/44 sounded better. So is it a case of upscaling making songs sound worse? Sorry I don't mean to take it OT, just something I wanted to clarify. TIA!
