Its because the figures are nonsense.
Hugo actual output is:
Output power - 1KHz 1V sinewave both channels driven 0.1% distortion
600 Ohms 35mW
300 Ohms 70mW
56 Ohms 320mW
32 Ohms 600mW
8 Ohms 720mW
Also Hugo TT share identical output stages, (except for increased bias current), same PSU voltage, same gain. So will deliver almost identical power for a given battery voltage.
Rob
Thanks Rob, still 70mW @ 300 Ohms does not sound like a lot of power, Has it got enough juice to drive HPs which are rated higher than 300 Ohms and above, like HD800S as an example? What is accepted level of output from a Headphone AMP for a good listening experience? Does Hugo do things different to to your Headphones?
Do you recommend using an external amp with Hugo TT or just the Hugo?
You do not need a lot of power for 300 ohm headphones. The HD800S will give 90dB SPL at 0.22v RMS; this means you will get 116 dB SPL from Hugo using HD800S; that is levels that will cause long term hearing loss, so yes it's plenty.
Unless the 'phones are crazily insensitive, I would not use an external amp - you will only lose transparency. Much of the supposed benefits of external amps is that it offers more distortion - and 2nd harmonic distortion thickens up the sound, making it sound phat with a bigger bass. Now if you prefer that then I won't argue - one's taste is personal. But it is not accurate.
I agree with Jazz - if you have 'phones that are too bright simply use some EQ. Better still is to purchase warmer headphones, such as the AQ nighthawks.
Rob
