Only digital inputs are found on Hugo and we only get an analog outputs. No analog inputs whatsoever.
Chord Hugo
- Thread starter harmonix
CosmicHolyGhost
Exhaustively burning holes in his wallet
- Jun 10, 2013
Is there actually anypoint in doing all the initial pressing to get into bypass mode?
From the Robert Watts interview: "Now the volume control - pressing the cross feed button at start-up does not eliminate the volume control, it only sets it up so that it has exactly the same gain as Qute. I added this so that I could do careful listening tests with Qute."
Can't remember where but someone commented that they got better results by reducing the volume slightly (to blue, IIRC)- but I think that was to a preamp for speaker use. More 'range' on the preamps volume control and slightly better sound too
Thanks for pointing out this...
I will try to use my 47lab preamp out to see. However, when I tried with my SS amp using the Hugo default vol level and off the speaker out (without any resistors) for HE-6, it still felt underpowered. However, I will try increase the vol from a preamp to see if I can yield better result than increasing the vol level of Hugo...
Hifi Nutter
Aka: ljuk, Will B, aoxomoxoa, sick, Why Aye, not now, trolls, PUP pie, 123scamp, chuk, pup piss, whoopee
aka Mrs Hifi Nutter, Hugo fan and numerous other aliases.
- Feb 23, 2014
Your welcome Hugo boss, at least everyone gets to see what the new chassis is like now, listening to it in the garden with the Mrs, superb!
Hifi Nutter
- Feb 23, 2014
I don't care what chord says it sounds well better as you run it in, wasn't mega blown away when I first put it on but after less than an hour it's really opening up, trust me chord ain't any different from any other expensive electronics, it needs running in fact!
CosmicHolyGhost
- Jun 10, 2013
Congrats! Hifi Nutter.... How are you using the Hugo in the garden?
with what headphone are you using it ?
Hifi Nutter
- Feb 23, 2014
Hifi Nutter
- Feb 23, 2014
I'm using sennheiser ie 800 and Mrs using the musical fidelity eb 33 which are amazing for 80 quid
Hifi Nutter
- Feb 23, 2014
Told her she got the best ear phones in the world lol
Hifi Nutter
- Feb 23, 2014
Just using my I phone 5s with the hd usb and lightning cable resting on a audiophile base platform, simple but superb!
Well, I'm sure you are not the only one confused because Chord have a 'volume bypass' section in the manual, which they say you need to activate for standalone dac use.
Perhaps it should be retitled 'max gain' mode because there is never any bypassing going on.
Rob Watts
Member of the Trade: Chord Electronics
- Apr 1, 2014
Glad to see you have finally got your Hugo. Now on warm up, I agree things sound better the more times you listen to Hugo. I have been listening to one since September, and I swear it sounds better now than then - it very much has the ability to surprise even 8 months on - I was listening to some castanets today, and the click was extraordinary - very sharp, and precisely focused. So is it Hugo breaking in, or my brain breaking in to Hugo, or is it that Hugo has the power to surprise like live music? I do not know - but I know that getting used to Hugo sound is not something that happens quickly, and it is something that you will find sounds better and better - but doing careful listening tests with old units and new units does not reveal a big difference in sound.
Another point in a posting earlier - it does not matter which source is selected, DoP will be decoded to DSD on all inputs.
Welcome to the forum!
Rob Watts
- Apr 1, 2014
hugoboss
- Mar 10, 2012
do u mean it also decode dsd from spdif and optical input? how
btw really glad you join here finaly ! welcome
