Whazzzup
Looking at the picture I see you also run the Hugo out of the left USB port of your MacBook Pro.
Do you guys know if there is any difference between left and right port in terms of SQ?
I couldn't hear any, also I wouldn't want to use the right port as it would be uncomfortable using the mouse
Im not sure which is left but the port with the on off switch is the hd port, the other sd port. Big difference and you switch between the two via the outer button toggle. The hd port enables 32 bit and up to 384 fr through your audio midi controller. Now i can tell the difference but that also depends on your quality of hp and sources. I can tell the difference between 16 and 32 bit and prefer 32 bit 384 so i usb to my HD port via my 5K iMac
Oops now I see you are referring to the notebook left side, ignore the above
