- Jun 7, 2007
Well at least you don't have exostosis in each ear……..
I do.
imho hugo has the sound quality difference at this price point which is very difficult to close, until someone uses almost similar technology like hugo. moreover 2qute has worsened the situation for other dacs.
can't argue with that, heartily agree... speaking as a Head-Fi'er obviously...
truly speaking i have not listened yggy. i believe, to make sound something sweet and musical in the world of dacs, there are two methods. either you make the dac a bit controlled in the treble region or use tech something like in hugo ie process the digital data in most transparent way. obviously first method is far easier but won't do justice with the realism and transparency of the music. so if a dac like yggy does not sounds good for poor (read bright ) recordings but does have extra perceived detail that means there is something which is not ok for a flagship high end dac. hugo on the other hand does not add anything to treble or bass yet has insane resolution and timing which make even so called bright or poor recording much more enjoyable. my test track for any dac or cdp is a song named 'aadat' of band named 'jal' from pakistan. songs were popular in india also. this songs has prominent cymbals which are very difficult to reproduce correctly for any dac. but hugo does it so beautifully that i have not heard any other dac doing that so cleanly. imho hugo has the sound quality difference at this price point which is very difficult to close, until someone uses almost similar technology like hugo. moreover 2qute has worsened the situation for other dacs.
Well at least you don't have exostosis in each ear……..I do.
whatever that meant.. hehe.
Ouch!Sorry for you! Not sure if I would prefer that. So no IEMs?
Edit-So Okay-Guy not too many cold waves just too many waves and over time it happens, but things could be a lot worse than getting too many waves.
Yeah well the customs(jh13) i have hit a little if i push them in too far, which is painful like really painful. I don't use them much anymore, i mostly have found iems that don't go as deep into ear canal. The biggest problem is that when my ear is sealed i have very loud footfall noise with iems. I don't know if this is from the condition or not. The noise varies in loudness, and seems to subside as i have the iems in for a longer period. The customs are pretty bad, i found a pair of vented iems at canjam that don't go to deep in my ear that worked perfectly. They are a little bright for me on some days but very refining and accurate otherwise and no footfall noise due to vents so happy me! They are called fi-ba-ss, you may have heard of them.
In addition, the opening is very small inside my ear canal so i don't know if that emphasizes my treble or bass, I think it would decrease treble- I have about 5%-8% room open on my left side and maybe 10% open on my right side.
In all, it was worth the forty three years of surfing for some minor discomfort with some iem's, and i don't need to get them drilled out at this point as most of my friends, so i'm good.
I still maintain that a good seal with ciems is not a complete seal. I know exactly what you mean about even hearing the footfall noise. Those FAD's you have, by the way, are very nice iem's!
hi, anybody used Hugo as preamp feeding to power amp and feeding a active sub from headphone out simultaneously ?
Not exactly but used as preamp feeding active monitor speakers with active sub (on which are connected the active monitors).
