hugoboss
- Mar 10, 2012
Our local dealer who has had the demo hugo that was at Ces and chord's huge desktop dacs still think overall that chord desktop dac above qute hd sounds better overall. They have been doing a ton of critical listening comparing the desktop ones to hugo. While hugo has newer dac chip that should be superior to desktop dac chip, the dac chip is just part of the equation of what makes the overall dac sound better. Otherwise all es9018 dacs would have little difference between them. The big chord desktop dacs are using significantly superior implementation including better power etc. I guess the superior implementation of the desktop dac outweighs the Hugo's superior dac chip, if local dealer is to be believed. But as someone mentioned earlier, you can carry the hugo with you. My guess is chord's desktop dacs will see an upgrade to the newer dac chips soon enough.
i have compare by my own in my local dealers before taking decision to buy hugo
1. chord qute hd (stock power supply coax input)
2. chord qute ex (same like above)
3. chord hugo (same like above without power supply coz hugo is battery powered)
listening to 3-4 songs.
hugo beat the qutehd and qute ex, in terms of details, soundstage, clarity. i can hear very clear diana krall taking breath in the girl in other room track.
but if you purchase high quality linear power supply like teddy pardo psu to replace the stock psu from qutehd and ex, plus usb to coaxial converter like matrix x-spdif or ifi usb spdif, maybe the qutehd and ex can beat hugo.
but the problem is the price of teddy pardo and the usb converter sum up to $369 ( teddy ) $250 (matrix) total $619.
yes $619 to maybe beat hugo.
hugo dont need fancy linear psu it's already have battery clean power supply onboard, plus the usb connection already so good.
about the chord flagship qbd, it's must be better than hugo but it's older dac chip, and far to many times hugo price.
in my opinion chord must hurry to refresh their dac lineup
as soon as possible refresh the qute hd and qute ex with hugo chip inside with better implementation considering the bigger space in desktop case than hugo.
maybe call it desktop hugo dac. to replace the ex and qutehd .
now potential buyer will likely choose hugo over than cute ex . the price is same 1200pounds. (before chord realize hugo price can be raised to 1400 pounds)
better dac chip plus mobility plus headphone amp, plus clean power from battery
