Dobrescu George
Reviewer: AudiophileHeaven
@Rob Watts I really admire your work! It is at the state of art point!
i really should get one for myself...
What sound? None has always been the goal. Hugo has never been tweaked or voiced to sound a certain way. Now, the objective is to make it sound as musical as possible, so that when you listen to music, you become emotionally involved, otherwise why do it? Trouble is, how does one relate that goal into engineering? My view has always been to make the design as transparent as possible, that is for it to add no sound signature at all. Now if one listens to live un-amplified live music, there exists an enormous gulf between the sound of real instruments and high end audio reproduction, and if all the pieces in the chain were perfectly transparent, we would be unable to tell the difference between live and reproduced - and we would get that glorious sound of acoustic instruments all the time.
Rob
At last we have a answer 2 why the Hugo TT users batteries . Maybe it's not 2 late 2 change the Hugo TT power supply Rob.
Rob
Would this be along the lines of the concept of The Absolute Sound: “the sound of actual acoustic instruments playing in real space” as championed by the late Harry Pearson?
If so, may I ask your thoughts on this:
If the Hugo is able to present the sound of a live acoustic performance as accurately as possible, does it follow that it should also present the sound of a studio recording as accurately as possible?
Cheers.
Yes, the sound of real acoustic instruments playing in real space is the only absolute reference. In my twenties I was a keen reader of TAS, and I was influenced by HP's thinking. I listen to real instruments as often as I can.
But, in reality, we use recordings to judge - for which we have no real idea of the real qualities as one was not present at the recording - so this is how the idea of trying to examine how transparent a device is by how variable the sound is. So in short, if a device has greater range of variation, in terms of timbre, space, instrument inner detail, instrument separation, etc., then it is more transparent. In short, the more expressive the music, the better the device.
Hugo is gaining acceptance in recording studios because the recording engineer can easily hear each instrument - how its placed in the sound-stage, pitch and timing, timbre qualities etc. Being able to easily hear everything in the mix clearly makes their job easier. So the goal is to be as accurate as possible. The problem with using the term accurate often implies in your face detail, which is not actually accurate. Accurate will mean rich and smooth if that is how the instrument sounds.
Now the ultimate non reference is electronic music, which of course has no absolute reference - but if you use variability as your yard stick, then it is a valid source to evaluate change, and indeed I use electronic music as part of evaluation, its great for assessing timing and rhythms.
Rob
The room changes the sound so I don't think live acoustic performances is the benchmark. The benchmark is an instrument played in a properly treated room in my opinion.
hmm, should i sell my hugo and get a TT instead... is there really a big different?
Rob
LoL.... I have learnt from headfi that all DAPs sound the same, and certain American company DAC is a giant killer before it is even released. The comment is everywhere on the internet, everytime there is an announcement of a new DAC and there is a follow-up comment saying that this to-be-released DAC will appear and wipe all other DACs out of existence.
This is the Shiit Mafia - I had an encounter with them as well. It's made in the U.S.A. - well - it must be good then!
Good stuff - I still want to see the industry settle on USB-B inputs for DACS : IMO its the most robust of all the connectors and the easiest to find aftermarket cables for.
