Quick question: Is it OK to leave it ON all the time? I read in Chord's website that it is OK to leave the charger connected but I was wondering if it harms to leave the Hugo turned ON.
As I use it mostly in my loudspeaker system it is a bummer turning it of/on everyday.
hi all, wanted to know what are the alternatives of usb audio player pro for android ? uapp player supposedly bypasses the internal android system and directly outputs the even dxd to chord hugo. on my android so far only uapp trial version recognized chord hugo. oknyo hf player, liztic player and neutron player did not recognize it.
cross feed brings the vocals and instruments more towards center of the soundstage . effect is more pronounced in some recordings like duke ellington - blues in orbit.
So - I managed to get an early bird special on the Pono player which is due to come out in October, though I'm not looking forward to paying even more money over in taxes to the UK government.
Anyway - Pono has a headphone out and a line out. What would be the best way to connect to a Hugo? And would it degrade the sound quality by doing this?
I'm hoping that this will create a 'third party opportunity'. Maybe Red Wine Audio will come out with a Pono optical or coax mod. Normally it would be pretty easy to hijack the S/PDIF data on the way into the DAC chip...
I'm not sure I understand your question. There were need to be some internal modding. You would need to grab the S/PDIF data on it's way into the dad, and route it to an external jack. It would be theoretically possible to do this without changing the exterior by using an existing mini jack. Vinnie, are you listening?
so my understanding is that you want a modded-Hugo so you can use a Pono as a source, yes?... I was asking if it was possible to make a cable with a mini-jack at one end & coax/optical at the other, hope that clears any confusion.
