Rob Watts
Member of the Trade: Chord Electronics
- Apr 1, 2014
Do I understand correctly that there is no way to use the Hugo's RCA outputs in line-out mode (not controlled by the volume knob) along with headphone outputs normally controlled by the volume knob? I was wondering if I could avoid unplugging headphones and resetting the Hugo to use it as a source to a different amp. (Benchmark DACs can easily be used this way, for example.)
No all the OP's are connected together internally. In a normal DAC you would have two I to V stages, then a diff to SE amps, volume control, and finally a headphone buffer, so its a very complex analogue section. With Hugo, analogue is very simple, all the work is done digitally, where it possible to do things perfectly transparently. So I have only one single OP stage that combines headphone OP, and I to V conversion in one stage. The benefit is the analogue is very simple (and hence transparent). The downside is there is no fixed DAC OP that one can buffer.
Rob
