rudi0504
- Jan 24, 2011
It's probably best we take a view on a case by case basis (no pun intended).
Regards
Thank you
Regards
Thanks Rudi, look like I need to get a lightening adapter.
Yesterday, I was trying bluetooth in office using my Sony Xperia Z as source. I picked up quite a bit of noise with sensitive CIEM Fitear C435.
I switched off and on the bluetooth and Hugo multiple times to reset the connectiom but the noise was consistent on each try.
Not sure if anyone has similar issue or could it be my phone compatibility with Hugo?
Hi George
After I use Sony ZX 1 and note 3 and ak 100 / 120 via bluetooth , I always shut off the Bluetooth on my DAP or note 3 , I hear no more noise on my Hugo
I have problem use bluetooth pair with IDevices like iPhone 5s and iPad air , at the beginning was fine after a while I hear distortion on the music instrument
Bluetooth operates on 2.4khz, the same as most WiFi devices, if you're in areas with high WiFi usage or other bluetooth devices in use in range of yours you may get some noise related to that congestion.
I'm running Hugo as a DAC right now, feeding a Taurus MKII which drives an HE6. Extremely impressive combo IMHO.
Yesterday night I tried my Hugo to drive my Abyss
the result : wow the most powerful portable set up I have now
It has more power than my 3 stags : ALO Rx 3 B + class solo original + iPhone 5s
Source : iBasso HDP R10 with optical out
Dac Amp : chord Hugo
Headphone : Abyss 1266
LCD XC
My impression
WOOOW the most powerful portable set up I have now
This is phenomenal in portable audio with audiophile sound quality
I did not expected before about chord Hugo power that's so power full
I drive the volume until light blue so powerful and NO distortion at all
at Mook I have tried 3 iems also no sound quality reduction and no distorsion
That's mean the power Amp quality from Hugo is excellent
Note : use optical sound quality is very good , I believe with COAXIAL cable is much better
IMO
Rudi, if you have time, could you compare the duet amp with the hugo's amp?
