seeteeyou
Living encyclopedia of product accessories.
- Jun 13, 2012
I have been having similar thoughts since I experienced Hugo. I had believed (not sure if correctly) that an advantage of higher sampling/bit rates mainly help to minimize timing issues for DAC. If Hugo (other any DAC) can do timing well for 16/44 Redbook, is there material advantage to have "HD"?
A question for Onkyo HF user, do you guys turn "upsample" on when using with Hugo? What does it do?
I was not trying to start a hirez war. I truly believe that some of my vast hirez library is no better than its redbook counterpart, but the majority is better, in some cases by a lot! And as posted before, some of this quality difference is simply the better kidd glove treatment, whether mastering or otherwise. My issue was more about the popular act of taking our collections and doing upsampling via software (player, offline, etc) or is the Hugo more comfortable with certain sample rates and therefore thought must be given to maybe even downsample some of our collection to take better advantage of whatever it is that the Hugo seems to do to sources (especially evident is redbook alchemy). If we take great well-done 24/192 native recordings (Barry Diamnet's Soundkeeper label, for example) and ask Hugo to do its best with it, does that mean keeping it at 24/192 or moving it to some other sample rate where Hugo is "forced" to do even more good things. (Note: I;m beginning to think I am overthinking this and its best to just give Hugo native everything).
I'm beginning to see why some people stick with vinyl - the only 'timing' they have to worry about is whether the platter is 45, 33 or 78RPM
(ok - there are other issues with turntables, but they dont have a choice of bit depth and sample rate !)
Are you saying onkyo HF does not play ape ?
For me PCM is always. Flac no compression. After that it's dsd .
Al
Well, the Direct Stream, the other FPGA entrant upsamples all to 30/28mhz (640fs) in DSD-wide, while the Hugo apparently does the same in PCM (2048fs). I would assume that these 2 being programmed by math eggheads would do a wonderkind job of the upsampling algorithm. However, Jussi knows his stuff too and he is using the entire raw computing power of the (potentially) i7 processor to upsample on the fly and his filter designs seem curring edge too.
Seems like a fair fight among the computer egghead engineers and one is free to pick their particular poison. One thing is clear though, people raving about DSD256 and 512, should be very curious about "DSD640" and "DSD2048"-technically PCM here. lol
