NZtechfreak
- Jan 19, 2012
The post did not say what phones as I have a note 2 is this included .
Thanks in advance
Most phones with USB host should work with this app Al, the app bypasses Android audio and has its own USB audio drivers, so it works with many Androids with no support for USB audio, and extends the DAC support for those that do (for example, I use the Dragonfly 1.2 with mine, doesn't work with the phone but does via UAPP - even including the amp volume controls from within the app - that form factor is so hard to beat for truly portable use!). There is a trial version available on the Play Store, so you can always check before buying.
Also, if you weren't aware 128gb cards are available for your Note 2 (and even full-size SD cards will work via an adapter and case mod, allowing for up to 256GB+phone internal memory on your phone - I'm using one in my phone now that PNY have released a 256GB SD card for ~$120USD compared to the $500USD price for the Lexar ones that came to market first).
