ALRAINBOW
- Oct 5, 2012
It played dsd 128 and 64 over coax. For me. The light was white. I have not ride the optical spidif on my iMac as yet .
Al
Al
I never found headphones as being all that great in staging at least compared to speakers. But those headphones are very much like listening to speakers.
Al
I've been using HD800's.
I can't wait for the HD850.
Really wow this is really cool. I will try it now.
With my offramp optical.
Thanks. The only DAC I know of that does this is the MSB.
what a DAC the hugo is. I do not know of any others.
Holy cow
Al
Maybe this is not relevant to the thread. But may I ask any link or news about the new Sennheiser flagship headphones?
Im sure you'll understand that nothing like Hugo existed before it's launch however the guys at chord may be contacting you for advise next time. Though I do wonder How many mobile products did you say you'd designed or is it that you only like to offer your advise after the products are on the market in any case I'd suggest you give them a call about your own Hugo it would be worth while I think.Actually I wouldn't limit the mistake to just the rca inputs. The reality is the mistake goes across all their input connections except for toslink. The rca inputs are the most glaring and almost comically so as any decent cable used for this level of product will not fit (I believe I had to steal the coaxial cable that came with my wadia ipod dock that was the only decent cable from my collection of 30-50). Remember the rca issue also effects the coaxial which would be a fairly common portable input. The problem also extends to the usb connection as well. The basic issue is the decision to use micro B usb which is a strange decision in itself. It might be a design limitation due to size but it seems like there might be enough room for standard B usb. By going micro B, they excluded basically every audiophile usb cable most people own. I have a half a dozen or so audiophile level usb cables and none are micro b. So I was relegated to using a belkin cable I had lying around. So I proceeded to buy the best micro b to b connector I could find which was from audioquest. Sorry the adapter doesn't really fit. It fits using a lot of force and any weight (and most good usb cables have some weight) will shift adapter slightly and break the connection. To use adapter I had to jury rig a support to sit underneath the cable and adapter so the weight of cable wouldn't pull connection apart I called the cable company which deals with high end cables and you would know, if you had dealt with them, how big their cable selection is including a massive lending library. The only micro b usb cable they could find me was from audioquest which also had to be special ordered along with the non working audioquest 90 degree rca adapters I bought , butam actually scared to open it for last week or so as the audioquest usb and rca adapters didn't work.
My guess is that the case designer error on the side of caution with regards to structural integrity. But was probably not as forgivable, they obviously did not do final design testing for very long. The earlier testing as likely done caseless or in test case where the error did not exist or someone found as working cable but forgot how big a pain it was to find one that would work. Final product testing would have quickly revealed so obvious a problem as basically 80% if not higher of cables would not have worked including most of their sister companies cables.
It has been a long time since I have had to purchase cables for any product. And I can't remember any product in recent history that I had to spend so much effort (which is still ongoing) to find acceptable working level of cables. Sure there are some ones made from companies I don't really know or even heard of. Before you argue any of this, first quote me the last product you got that took anywhere this level of cable matching simply to find one that works? Not having a working cable is pretty basic mistake. I do commend chord on sort of fixing the problem as soon as they did. I would love if they would fix the problem for me as original owner. But please next time spend some time on final product testing or they need to overhaul their final testing procedure.
Hi, it sounds like we have the same taste. I enjoyed the HD650 myself, but it took about a week for my ears to adjust the difference from the sea of bright phones on the market. I prefer details and clarity, but without the compromise of warmth which brings the realism in. I look for a balance of it. Wolfson has the warmth, but doesn't do well when it comes to details. The mobile ES series are cold sounding, but the non-mobile ES9018 sounds highly resoluted with good amount of warmth. Probably the best sounding DAP I've run across so far. Never heard the Hugo, but I don't like overly bright sources.
For musical I would recommend HE-6. It's the most balanced I've heard. the drawback is, it's stage is not as big as the HD800, more intimate, but it's very musical and detailed, which I don't find with lots of phones. Also, needs a powerful amp.
e USB closest to the power slide switch .... is the High data rate input. So that is why its finding itI was following this thread up until page 300, but it seems to have exploded since then, so I've got some catching up to do!
I've just got home to test out my Hugo, but am having an issue that I'm assuming I'm being stupid over;
If I connect my Macbook Air using USB to the HD USB input (the one on it's own), then my Macbook identifies it as a USB Audio DAC, which I then set in Sound (and in Audio MIDI setup) to be the default, then I get no sound. However, as soon as I switch to the SD USB input (located next to the power switch), then my Macbook identifies it immediately as a Hugo and it works straight away... am I missing something?
Cheers,
Stick a beefy amp in-between the Hugo and the HD800s and the HD800s can really party.
Th
Guys I wanna make a vote, as my budget are very limited, if I wanna choose 1 headphone for the Hugo and options are only HD800 & TH900, which one would you guys recommend to get and pairs with the Hugo (no external amp)?
