Rob Watts
Member of the Trade: Chord Electronics
- Apr 1, 2014
Rob Watts reportedly - and I havent seen the original claim - prefers the optical (Toslink) connection. I'd suggest that you try them all for yourself if possible.
Yes I have said many times that I prefer optical.
I have not done this listening test for many years - I just use optical always and that's that - I thought I would re-do the listening test. In this case, whilst listening between optical and coaxial, I disconnected the input as well as switched the source button.
Optical was indeed as I listened before - it is noticeably warmer, smoother, with better timbre variations on individual instruments and better instrument separation. Now it also sounds softer, as it is less hard and on a superficial basis is less impressive - the hardness can easily be confused with more detail resolution and impact. But it's a lot more natural.
Now optical gets a lot of bad press - more jitter etc. In the case of Hugo, the jitter levels does not matter, as everything gets re-timed against a low jitter clock, so source jitter is completely removed. Incidentally, the AP test equipment actually measures lower jitter levels on optical than the coaxial inputs, so the jitter story is, in this instance, false.
The benefits of optical is that it isolates the Hugo from the sources' ground injected RF noise. Now anybody reading my posts will say that I am a bit of a timing freak, but I am also a noise floor modulation freak too. RF noise, when it is mixed inside the active analogue electronics, creates inter-modulation distortion which results in the noise floor moving up and down with the analogue signal. I have measured this effect, so I know it is real, and reducing RF noise results in measurable reduction in noise floor modulation. Also I have seen on digital simulation extremely small levels of noise floor modulation, which when removed produces a very audible effect. So the ear/brain is somehow extremely sensitive to this problem.
So how does noise floor modulation account for the observed sound quality changes? Firstly, better instrument separation. Now imagine two instruments playing in a system that has noise floor modulation. You will get noise floor modulation that is a sum of both instruments. Now when the brain has to separate the sounds out, it has now 3 signals to worry about - the two instruments, plus the noise floor modulation which is a combination of both instruments. This confuses the brains processing to be able to tell instruments apart, and hence degrades the brain's perception of the instruments as being separate entities, because you have noise singing along as a combination of the two instruments. This confusion also makes it difficult for the brain, which then will give you listening fatigue.
How does it explain timbre variations? Now imagine listening to one instrument - a saxophone - something rich and smooth sounding. Now noise floor modulation is white noise pumping up and down with the signal level - it has the timbre of hiss, that is very bright sounding. Now add some noise floor modulation, and you are mixing into the sound of the sax something that sounds quite bright. The brain can't tell the difference between the sax, and the noise floor modulation which is proportionate to the sax signal level. So it lumps the timbre together, the rich sound of the sax becomes brighter and less like a sax. We actually end up with all instruments sounding bright, so timbre variations are suppressed.
How does it explain it sounding softer? Well, if you have noise floor modulation, you get more noise with the music peaks, and this often occurs at the initial starting transient - so you get a burst of noise on peak transients, which artificially enhances the sound - it's the MSG of sound quality.
Many people have reported Hugo as having wide timbre variations - being able to distinguish different timbres on different instruments and noise floor modulation (or rather lack thereof) is one big reason for this. In the case of Hugo, I have been working hard in the digital and analogue parts on not merely trying to reduce noise floor modulation but to eliminate all sources of it.
My final point is this - be very careful about listening tests, and, in my view, the goal is to enjoy music, not to think the sound quality is impressive. At the end of the day, go for the more musical sound - testing for musicality takes a lot longer, but it is the ultimate goal.
Rob
