sutjahjo
- Jan 2, 2013
Hi Moe
Please Dont see at the silicon , please see My Friend set Up With his Hugo
You Will Love more Your Hugo With Coax cable
Hi curious, can you elaborate on the connections?
Hi Moe
The saying goes you work to live or live to work or work to listen to top hifi
The only reason why I am after an amp is because I don't like the silicon knob on the HUGO.
Personally I love the knob.
God, did I really just write that.
Steve jobsNo one ever looked back in their life and wished they had spent more time at work.
You missed all the fun last night, it's from a pair of Crystal Cable Dreamline interconnects for $7,700
http://www.head-fi.org/t/633511/pictures-of-your-portable-rig-part-xvi/11970
That's beginning with a modified AK120 with coaxial output, Dreamline 3.5-mm to RCA coaxial cable, Hugo's coaxial input, Hugo's 6.3-mm output, 6.3-mm to 3.5-mm adapter, Dreamline 3.5-mm to 3.5-mm TRS cable, 3.5-mm female to female coupler, and FitEar 001.
DIY Dreamline should cost almost $1,000 a piece according to Rudi, that's his friend spent roughly $7,000 for the whole transportable rig.
Rudi what is your view of ZX-1 and HD USB? Is coaxial still better? I currently use my C4 with HUGO for it and like it alot.
Coaxial is the best SQ from Hugo
My experience of it popping in an out is use of 3.5mm optical adaptors, which do not work well. I asked Matt at Chord, and he kindly replied on a Sunday morning and said:
" This sounds more like a problem with the optical cable or the 3.5mm optical adapter. The AK products and the Mac both use the 3.5mm optical connector which means you need the special cable or adapter. I have had various reports of the adapters not working or breaking the signal. We can supply a known working toslink to 3.5mm cable if required. Many of our distributors have spare stock of cables they can send out."
Hi VZ and Rob
So far I have not problem with my Hugo , I am still waiting the new chassis coming by end of this month.
I just know from joseph sys Concept , as my friend asked me why his sys concept toslink to toslink use mini plug adapter can transfer only 24 biit / 96 KHz .
Joseph answer :
Mini plug adapter block the flow from the optic signal reduce to 24 bit / 96 KHz
The best solution I must order toslink to mini plug , or mini plug to mini plug
Hi VZ and Rob
Joseph answer :
They should not charge for the new chassis (shipping charge ok), since they made the mistake of making the holes too small.
