elviscaprice
- Apr 16, 2014
Received the 2tb seagate wireless plus today. What format files are required to stream 192 files? It isn't recognizing aif files thru CCK into HD USB. If I change the extension to aiff then it worked sporadically. Any advice?
You did notice that when you use the wifi connection, Seagate, it is a slow connection, edit: I've gotten different info on this. That would be a problem for hi rez, I would imagine. So you must hard wire the drive to the playing device and then to the Hugo? Correct? But then that defeats the purpose of the drive? no?
Here's how fast the wifi is when streaming. This is probably why your having drop outs would be my guess.
Does Seagate Wireless Plus stream in HD?
It is capable of streaming in HD up to 10 megabits per second but some devices may not support High Definition formatted videos.
